Advice on Blocking up Upstairs Doorway in Brick Wall
Sim22
by Sim22 » Wed Apr 06, 2016 7:56 am
Just need to check, I have removed the wooden frame, the wall is brick construction, so I should use light breeze block? Metal ties to bond to wall. Do I need to lay anything on floorboards or place mortar straight on before starting the block work?
Re: Advice on Blocking up Upstairs Doorway in Brick Wall
by welsh brickie » Wed Apr 06, 2016 5:35 pm
you will need to remove the floorboard and build on the brickwork below the floor.
Or use 4x2 timbers and build a stud wall to block up the doorway, insulate it and plasterboard
Sim22
by Sim22 » Wed Apr 06, 2016 8:07 pm
Thanks that's great. I was told to use block work as the best solution, so that's what I will do
It is currently Sat Jan 04, 2025 11:06 pm
