Help With Removing a Wall to Wall Tiled Fire Surround
Lauren83
by Lauren83 » Mon Apr 11, 2016 12:06 pm
We have inherited a wall to wall tiled fireplace which is quite old fashioned (70s-80s) and we would like to completely remove it. The problem is I'm not very sure where to start! I have had a bash at removing one of the lower tiles and it appears to be concrete below. Any help or guidance as to how to tackle this would be much appreciated it definitely has to go!
Couldn't add an image unfortunately
lets have a look
Re: Help With Removing a Wall to Wall Tiled Fire Surround
by lets have a look » Tue Apr 12, 2016 6:34 am
did you remove a tile from the hearth,photo would be helpful
Lauren83
by Lauren83 » Thu Apr 14, 2016 10:02 am
Yes. I've also removed some tiles from the chimney breast and again there is a mix of concrete and metal behind this.
lets have a look
by lets have a look » Thu Apr 14, 2016 4:29 pm
there might be 2 retaining clips buried in the plaster about 9" to 12" down from the top,I should imagine that it is a pre made one,lever out the surround might be heavy, then lever up the hearth,then you would have to make good.
It is currently Fri Nov 15, 2024 10:38 am
