How to Install Drainage and Soak Away from Rainwater Downpipe
Sim22
by Sim22 » Tue Apr 12, 2016 10:23 am
The drain at the bottom of the downpipe seemed to be blocked, after inspecting and digging out the drain collapsed and I discovered that there was no further drain to a soakaway, which I assume is why this corner of my living room has a damp problem as the clay soil is pooling the water and allowing limited drainage. What do I need to create a drain to move this water? I have purchased a bottle gulley and a few lengths of standard pipe and my intention is to dig a trench and then a soakaway at the end of the pipe work. Have I missed anything and is this the most effective way of removing the water from the downpipe.
lets have a look
Re: How to Install Drainage and Soak Away from Rainwater Downpipe
by lets have a look » Wed Apr 13, 2016 2:59 pm
yes or connect to a main drain if located nearby
by welsh brickie » Wed Apr 13, 2016 7:39 pm
you will need to dig a large hole 1 metre square and at least 1.5 metres deep. The pipe must be laid on, and covered with pea gravel.
Line the hole, with a geo textile fabric and then install a soakaway crate, lay the pipe into the crate and cover it all with the fabric. and refill.
It is currently Sat Jan 04, 2025 11:01 pm
