Internal 9 Inch Damp Wall and What to do Apart from DPC Injection
bikerchris
by bikerchris » Tue May 24, 2016 3:05 pm
Hello all,
This is my first post on here, looks like a really useful website.
I was wondering if anyone could help as I have a problem wall, which is the party wall between me and an internal garage. I've taken some pictures, as you can see damp has damaged this wall really badly, I think this is partly down to the timber boarding which did cover it originally.
I've started doing DPC injection 2 courses above the finish floor level, but I just wonder what I should do with the brickwork? The long way (I'm guessing) is to support small sections with acros and rebuild, but I would prefer not to! I wonder if I can do anything less time consuming? Some of the wall is 'missing' from the external in by upto 4 inches...it's really bad!
Look forward to any comments.
Cheers!
Chris
my side close up
my side close up
my side
my side
from garage
from garage
bikerchris
Re: Internal 9 Inch Damp Wall and What to do Apart from DPC Injection
by bikerchris » Wed May 25, 2016 10:07 pm
Bit of an update, but I the problem part of the wall is about 9 feet wide. and probably 15 odd courses high, if that helps.
So far I'm thinking it just needs supporting, then re-build in small sections.
by welsh brickie » Sat May 28, 2016 11:36 pm
paint the wall with S.B.R solution, and render the wall with sand ,cement ,lime, mix, ratio 4:1:1. Use a comb as its called, to scratch the render, and apply another coat when its set.
Keep applying till the desired thickness is achieved.
bikerchris
by bikerchris » Tue May 31, 2016 9:40 am
Thank you Welsh brickie, really appreciate it.
Is this the correct stuff?
http://www.wickes.co.uk/Sika-SBR-Admixture-5l/p/133789
That's really great advice, really appreciate it. I'm wondering if the wall is too far gone for repair, because when I was drilling for the DPC injection, the wall was just falling apart! I kind of stopped at about 3 holes, because I was worried the wall might just fall down (on me!).
Cheers again,
Chris
It is currently Wed Jan 15, 2025 7:12 am
