Bathroom Rendering and How to Prepare Bricks for Render
harryuk147
by harryuk147 » Sun May 29, 2016 11:37 pm
hello,
I wish to render my bathroom walls, they are double skin cavity walls, nothing major. I wish to know how to prepare the bricks? Does anything need to be done to them or can they be cleaned up and wet down? When i run my hand along them, they feel kind of smooth, i am a bit worried that the render will not adhere properly.
Can anyone help me,
Thank you
Re: Bathroom Rendering and How to Prepare Bricks for Render
by welsh brickie » Mon May 30, 2016 4:47 pm
if you want to render the wall, then you need to paint a pva solution on the wall first.
If its internal, have you considered dry lining?
harryuk147
by harryuk147 » Mon May 30, 2016 5:28 pm
Hello. I wish to render only, not board anything. I am reading that i should rake the joints out also, is this correct? the bricks are quite smooth.
by welsh brickie » Thu Jun 02, 2016 7:36 pm
ok then, use SBR additive and mix in a couple of cups of cement, it forms a paste that when set will give you a good key for the render.
It is currently Wed Nov 27, 2024 10:40 am
