How to Replace Tiles with Laminate in Bathroom
amsbam1
by amsbam1 » Wed Jul 27, 2016 1:16 pm
I want to replace my bathroom tile floor with laminate. Do you recommend laying the laminate on the tiles (perhaps with some foam between) or ripping up the tiles?
The floor underneath is T&G softwood (there may also be plywood between).
Re: How to Replace Tiles with Laminate in Bathroom
by welsh brickie » Wed Jul 27, 2016 9:41 pm
its best to lay it over the tiles, using a foam underlay ,taking it up it a lot of work
Tile Devil
by Tile Devil » Tue Aug 02, 2016 11:01 pm
I agree with welsh brickie. Just have a quick inspection of the floor to make sure there are definitely no leaks or any loose tiles. If there are, pop them up and replace with a piece of ply with the correct thickness.
Also check that you will have clearance to open the door!
amsbam1
by amsbam1 » Wed Aug 03, 2016 10:09 pm
I need to take it up so it seems so the floor will be nicely on the same level as the next room anyway. Pity, here's to scraping tile cement.
It is currently Sun Nov 24, 2024 1:07 am
