Removing Dead Wires and how to do This Safely?
ID015
by ID015 » Sun Oct 16, 2016 9:27 pm
There is a dead wire that is poking in and out of one wall and I would like some suggestions in what would be the best course to remove it.
I tested and it's dead; it's an old house so I am suspecting it used to bring power outside, though the cable outside is cut off and there's another similar wire inside but it's also cut off.
I am dying to pull it cause I don't like it visually - though needs to be done safely.
Ideas?
kbrownie
Re: Removing Dead Wires and how to do This Safely?
by kbrownie » Mon Oct 17, 2016 9:23 pm
I would suggest that you do a continuity test on the conductors, to establish that they are one of the same cable, then pull it out!
ID015
by ID015 » Wed Nov 30, 2016 4:39 pm
I found the wire at the end!!!! It connects the old door bell which is powered by batteries. I guess when it was installed wireless door bells didn't exist!
It is currently Fri Nov 15, 2024 2:26 pm
