Operating a Armitage Shanks S9000 Isolating Plastic Outlet Valve
EamonnG
by EamonnG » Wed Oct 19, 2016 7:39 pm
Hello Everyone.
I need to turn off the mains water supply to a toilet cistern, to fix a problem with a leaking inlet valve. There is an isolation valve between the mains supply and the flexible hose to the inlet valve. It is an Armitage Shanks S9000 Isolating Plastic Outlet Valve, as pictured.
I tried turning the handle to the right (clockwise), but it is very stiff, and not sure it moved at all. I'm worried that I might do some damage if I force it, plus it is on mains pressure. Few questions please :
- am I turning it correctly i.e. to the right (clockwise) ?
- the handle seems to depress a bit, should I depress it, then turn it ?
I've also included a picture of the valve as installed :
Any help greatly appreciated, thanks in advance guys..
EamonnG
Re: Operating a Armitage Shanks S9000 Isolating Plastic Outlet Valve
by EamonnG » Tue Oct 25, 2016 6:30 pm
...and the answer is...yes, it does turn to the right to isolate the water. Hopefully that may be of help to others in the same boat..
As it happens this valve was also leaking at both ends, due to some shocking plumbing that would embarrass even me as a DIYer. I removed and replaced it with a nice and simplle pushfit isolation valve, as part of the overall repair job.
It is currently Thu Jan 02, 2025 8:45 pm
