Laying Laminate Flooring Following Previous Cuts
Dale1995
by Dale1995 » Sat Nov 05, 2016 2:52 pm
Hi I have never tried laying laminate flooring before so I was thinking if I took up all of my old laminate flooring and mark each piece with a number then cut each piece of new flooring to the same as the old is there any reason why this wouldn't work all fit, all of my skirting boards are on clips from the last person which I payed to lay the floor so the skirting boards just clip off from the wall. Thanks
Re: Laying Laminate Flooring Following Previous Cuts
by welsh brickie » Sun Nov 06, 2016 5:58 pm
All, you need to do is make sure there is a 300mm minimum overlap on each board, and take your time.
The boards need to be acclimatised to the room so open all the packages 24hrs before laying them
It is currently Mon Dec 23, 2024 4:02 am
