How to Raise Level of Block Work Rendered Wall in Spain
Magik58
by Magik58 » Wed Jan 11, 2017 3:05 pm
Need advice on how to raise the level of a rendered block work wall I have attached photos of the wall. I want to raise level of the two pillars by two blocks and then fill in between them. The wall is rendered and covered in tiny stones or grit that is thrown at the render as its drying. I want to cover this with just standard render I can paint. My questions are as follows
Do I need to remove all the render or can I use blocks just short of it and then apply scratch coat to level it and the apply finish coat over all the wall ?
Do I need to incorporate steel, the wall is 2m high max.
What mortar mix do I need ? (Spain)
What render mix for scratch and finish (Spain)
Should I use wall starter strips at the pillars ?
Think that's it.
thedoctor
Re: How to Raise Level of Block Work Rendered Wall in Spain
by thedoctor » Mon Jan 16, 2017 6:38 pm
You can but I would suggest building the new work flush with the existing ad applying a scratch coat over both after painting the existing work with a PVA/water mix of 2 - 1
Not necesssary
4 sand - 1 cement
Scratch = 5 sand - 1 cement - Finish 4 sand - 1 cement
Yes if the wall is 2m high it will ensure stability
Magik58
by Magik58 » Tue Jan 17, 2017 4:13 pm
Hi thedoctor
Many thanks for your reply and advice.
I have ordered some wall starters from screwfix eu as not available in Spain, so should be able to start work in a few days.
Muchas gracias
Magik58
Magik58
by Magik58 » Mon Feb 13, 2017 2:51 pm
Just an update on my wall it is now complete as can be seen by attached pics i have never done any brick/blockwork before or any rendering so I'm very pleased with the result and would just like to thank you once again for the advice given.
Regards
Magik58
It is currently Fri Nov 15, 2024 3:47 am
