Tumble Dryer Venting and Adaptor for Opening
6 posts   •   Page 1 of 1
reluctantdiyer
by reluctantdiyer » Sat Jan 28, 2017 9:21 pm
I need to connect tumble dryer hose 110mm diameter to external wall. Problem is that external wall hole consists of a 100mm metal sleeved opening. Is there an adapter that will allow the dryer hose 110mm to connect to one side and then push fit into the metal sleeved opening.
Thinking it might be easier to get a condenser dryer?
GayEddie
Re: Tumble Dryer Venting and Adaptor for Opening
by GayEddie » Sun Jan 29, 2017 4:50 pm
reluctantdiyer
by reluctantdiyer » Mon Jan 30, 2017 12:22 am
Thanks for the quick response.
I have seen a number of kits like this but don't think they will work for me. The house I moved into already has the hole, vent cover etc but it is only 100mm in diameter. My dryer has a 110mm hose so I am looking for something I can attach to the end of the hose that will step down to 100mm that I can simply push into the metal sleeve that spans the cavity wall opening.
This would connect the 110 hose to the smaller 100mm opening. Haven't seen anything like this despite searching.
Could consider enlarging the hole but will probably go for a condenser.
GayEddie
by GayEddie » Mon Jan 30, 2017 7:31 pm
reluctantdiyer
by reluctantdiyer » Tue Jan 31, 2017 11:26 pm
yes I will need something like this but the link you have given is to enable a 100mm to 100mm connection. I have a 110mm flexible hose that needs to be inserted into a 100mm outlet in the wall. Obviously this is not possible so I am looking for a connector that will allow the flexible 110mm hose to be connected by a nylon tie and the other end of the connector if it is 100mm can be siliconed into the wall opening. Haven't found one yet!
thanks
GayEddie
by GayEddie » Wed Feb 01, 2017 5:46 pm
I think that will go inside 100mm ducted it is for joining two 100mm duct together then I would cable tie your flexi duct to the other end.
Toolstation also offer free shipping for orders over £10.00
It is currently Mon Nov 25, 2024 12:08 pm
