Low Profile Shower Tray not Draining Away
kingpete16
by kingpete16 » Tue Feb 21, 2017 6:32 pm
I have a large 1600 x 800 low profile stone shower tray, after use, a fair amount of water is left along the back edge. Does anyone know the amount that is tolerated in millilitres before I can complain "the mould is incorrect/ or I have been sold a second " ? I don't want a build up of limescale and discoloured area as well as a breeding ground for bacteria !! Thanks
Re: Low Profile Shower Tray not Draining Away
by stoneyboy » Wed Feb 22, 2017 6:55 pm
Hi kingpete16,
The first question is whether the tray has been installed level.
Put a level on the top of the raised sides - not in the base.
Regards,
kingpete16
by kingpete16 » Wed Feb 22, 2017 8:02 pm
Absolutely level all the way round, that's been checked that's why I'm convinced the shower tray is faulty, is there a tolerance amount of water left behind that manufacturers work too, as I have loads left ? Is there a standard measure ?
by stoneyboy » Fri Feb 24, 2017 7:23 am
Hi kingpete16,
I don't think there is any recommended standard for the falls in a shower tray and unfortunately with so much coming from China quality is going downhill.
Sounds very much like you have a faulty tray and it will have to be replaced.
Regards,
kingpete16
by kingpete16 » Fri Feb 24, 2017 10:30 am
Thanks Stoney ! I'll continue to do some more research but it definitely looks that way :(
It is currently Mon Dec 30, 2024 10:35 pm
