Cut Wall Chase too Deep for Sink Hot and Cold Supply
Macca_andy
by Macca_andy » Mon Feb 27, 2017 9:09 pm
I was trying to chase a wall to put a hot and cold supply in (with insulation) to a sink. I used an SDS drill with chisel and things went way too deep (eek). It's even punched through the inner wall. Any tips on what I can do to sort this out? I've uploaded a couple of pictures.
Re: Cut Wall Chase too Deep for Sink Hot and Cold Supply
by stoneyboy » Mon Feb 27, 2017 10:54 pm
Hi Macca_andy,
I assume you ave pushed the bricks into the cavity, if this is the case retrieve as much as you can and rebuild back of the wall chase using a sand/cement mortar.
Regards, stoneyboy
Macca_andy
by Macca_andy » Tue Feb 28, 2017 7:00 am
Cool. That's great. Thanks.
It is currently Fri Nov 22, 2024 6:41 pm
