Installing Plywood Subfloor to Install Engineered Wood Floor on top
davidr83
by davidr83 » Sat Jun 17, 2017 11:05 am
Hello,
I'm looking to install a plywood subfloor, to install engineered wood floor on top. One thing I'm unsure- what thickness plywood should I use ? And what depth screws should I use, if i'm going into floorboards underneath ? Should I use self-countersinking screws for this?
Thanks!
David
SamCo
Re: Installing Plywood Subfloor to Install Engineered Wood Floor on top
by SamCo » Mon Jul 08, 2019 9:26 am
Hi David the engineered flooring is built on ply? its part of the product.
You can just float it on the existing floorboards
It is currently Thu Dec 26, 2024 7:22 pm
