Hi there,
Over four years ago I repaired about two metres of roof verge using a mix of 4 sharp sand to one of cement. The good news is it is still as solid as a rock. I used this mix because as a complete roofing novice I happened on to this site:-
http://www.diy-extra.co.uk/repairing-roof-verges.html
I'm now about to replace the lot but since then I've been on other websites that suggest completely different mixes. eg 3:1 sand cement etc.
Can anyone give a good reason why I shouldn't use the original mix. I might add that the gap between tile and roof is quite large.
Thanks in advance for your thoughts and advice!
Kev
