Repairing a Bosch GWS 8-115 Angle Grinder
mcaddy
by mcaddy » Tue Aug 22, 2017 10:22 pm
My Angle Grinder stopped working some time back and after popping off the case I quickly diagnosed the fault, the Suppression filter had visibly failed. Without a Job that required it I never got round to fixing. However the time has come to use again and I've bought a replacement part but have lost the notes I made about which cable connected to which.
I've got hold of the exploded diagram but I'm not having much luck working out which is which.
The Unit I have (which is identical to the faulty component) doesn't quite match the one in the diagram
Any Ideas?
mcaddy
Re: Repairing a Bosch GWS 8-115 Angle Grinder
by mcaddy » Wed Aug 23, 2017 11:06 pm
I know it's kinda bad form to answer your own questions but I figured I do it anyway as I managed to solve my problem thanks to some Russians!
I wasn't getting very far with the exploded diagram as the outputs on the filter didn't really correlate with the layout in the diagram.
Whist searching for a datasheet for the filter I stumbled across an Russian Language forum with some photos of a partially dissembled grinder. luckily this was just enough for me to trace the cables.
http://www.mastergrad.com/forums/t17253 ... -gws850ce/
Hopefully this will be of some use if anyone else is looking through past topics in the future.
It is currently Thu Nov 21, 2024 9:15 pm
