Connecting bathroom extractor fan to pull cord light switch
diyjunior
by diyjunior » Sat Aug 25, 2007 3:53 pm
I have an extractor fan with Live, Neutal and Earth. i want to connect it to a pull cord light switch. connecting to the light switch is earth and 2 red wires. one red wire goes to port called COM and the other goes to a port called 1A, i have an empty called 2A. please can someone advise what i need to do to connect the fan to the light switch? thank you
BLAKEY1963
Re: Connecting bathroom extractor fan to pull cord light swi
by BLAKEY1963 » Sun Aug 26, 2007 10:30 pm
[quote="diyjunior"]I have an extractor fan with Live, Neutal and Earth. i want to connect it to a pull cord light switch. connecting to the light switch is earth and 2 red wires. one red wire goes to port called COM and the other goes to a port called 1A, i have an empty called 2A. please can someone advise what i need to do to connect the fan to the light switch? thank you[/quote]
DIYJUNIOR
THERE IS NO NEUTRAL AT YOUR LIGHT SWITCH, ONLY A LIVE AND SWITCH LIVE.
A ALTERATION OF YOUR LIGHTING POINT IS REQUIRED AT THE LIGHT
FITTING TO CONNECT EXTRA CABLE FROM FAN UNIT.
THIS IS NOTIFIABLE WORK AS BATHROOM IS CLASSED AS A SPECIAL
LOCATION.
U NEED 2 GET A REGISTERED PART P ELECTRICIAN IN.
BLAKEY1963
by sparx » Sun Aug 26, 2007 10:31 pm
Hi, short answer is you can't!
the sw only has a permanent live in and a switched live out to light. no neutral.
so you have to run twin & earth to your light and connect to the same terminals as the lamp holder, also you must connect the earth in with the others in light fitting. as in a bathroom this is not legal DIY & if room has no window ie no natural light it should also have seperate local isolator sw. so light can be on while servicing 'dead' fan
Regards SPARX
It is currently Mon Jan 27, 2025 8:22 pm
