Are These Fittings at 3/4 and W20 the Same?
mjojom
by mjojom » Tue Oct 31, 2017 10:10 am
Hi All,
I am almost at the end of my project (fitting LPG heater) and need to connect reducer in between the tank and heater.
I Bought cavanga regulator which on one side is 8mm compression and other side W20 that I need reduced to 8mm compression too.
I never heard of w20 before but found two fittings and I need help to figure out which one.
first one that I prefer is JIC 3/4UNF to 8mm from lpg shop (lpgshop.co.uk/female-jic-to-8mm-reduction-for-4-hole-tank/)
and second one is Gaslow 8mm x W20 with test point (test point i dont need) (gasproducts.co.uk/caravan-marine/gaslow-gas-fittings-and-regulators/gaslow-regulator-adapter-gauges/gaslow-8mm-x-w20-with-testpoint.html)
could someone please tell me if both fittings are the same ie 3/4 and w20 ?
cheers
jo
It is currently Thu Nov 14, 2024 4:23 pm
