Mixer Shower not Getting Hot but gets Luke Warm When Toilet Flushed
Ssnow66431
by Ssnow66431 » Sun Dec 17, 2017 1:50 pm
Hi all.
Just moved into a new house which has a mixer shower however we only get cold water. We can get Luke warm water if we flush the toilet at the same time.
A friend has told me the shower water feed is the wrong way round. I have included a pic.
Any help would be appreciated
Shower as you look at it
Skid Sprocket
Re: Mixer Shower not Getting Hot but gets Luke Warm When Toilet Flushed
by Skid Sprocket » Wed Dec 20, 2017 5:40 pm
Ssnow66431 wrote:Hi all.
It sounds as though you have the cold feed to the shower from the mains and the hot feed from a tank. When you flush the toilet you reduce the mains pressure which is then closer to the hot (tank) feed pressure. Both hot and cold feed should originate from a tank to be at the same pressure. Guessing a bit but I hope it helps.
williamnorman
by williamnorman » Mon Jan 08, 2018 4:37 pm
is the water system low pressure?? ie a hot water tank or do you have a combi boiler installed??
Ssnow66431
by Ssnow66431 » Tue Jan 09, 2018 2:44 pm
It's a combi boiler.
It is currently Sat Jan 11, 2025 12:45 pm
