Changing Ceiling Rose to 3 lamp ceiling light
marvin900
by marvin900 » Mon Aug 27, 2007 3:29 pm
I am an novice to electrics and want to replace the current ceiling rose with a new 3 bulb ceiling light.
I have 2 x core wires coming from the ceiling, both with a red, black and earth cable. These were connected to the ceiling rose. I have disconnected and marked up the core for the switch. The black for the switch was connected to the live bank in the rose.
The new ceiling light fitting has a connector block with what appears to be a new "Grip" connection for the cables.
However, the problem is that connector block only has 2 holes for each of the live, earth and neutral.
Am I correct in thinking that the black neutral for the switch core needs to be connected to one of the live points?
If this is the case, this would mean that I would be left with 2 x live red cables (one from the light core and one from the switch core) but only one live connector point on the block.
How do I connect the final two live cables (assuming I put the other neutral and earths in the other points in the block)?
I hope this makes sense.
Thanks.
thedoctor
by thedoctor » Mon Aug 27, 2007 8:28 pm
Please go to the electrical projects on the website as advised. There is a link above and all your answers are in there. See especially replacing a light fitting.
BLAKEY1963
by BLAKEY1963 » Tue Aug 28, 2007 12:36 am
[quote="thedoctor"]Please go to the electrical projects on the website as advised. There is a link above and all your answers are in there. See especially replacing a light fitting.[/quote]
MARVIN900
TRY DOC S GUIDANCE
BLAKEY1963
It is currently Mon Jan 13, 2025 9:05 am
