by LCL »
Tue Sep 11, 2007 3:48 pm
Absolutely definately. There are very few alterations that you can do to a property that do not require building control approval. Speak to your local council, they will be able to help, but a few pointers:
What are the size of the floor joists and what is their span? they will probably require upgrading.
If the windows do not open, there is no means of escape. New windows or modifications to the exisitng will be required.
The building inspector will look at things like structural stability, heat loss, fire proofing, means of escape, safe access via the stairs, energy efficent lighting, sound proofing the the house.
As it is residential you can do it under a building notice. This requires the person carrying out the works to notify building control as the work progresses and if you are doing it yourself you can ask their advice. If you are thinking of employing a builder, get some proper plans drawn up. The works amy also need a structural engineer or and possibly a party wall surveyor. find a surveyor.
Hope this helps.
