First Home Improvement Project Plastering Walls and Sanding Floors in Flat
EdinburghFlat
by EdinburghFlat » Tue Feb 06, 2018 12:02 am
Hi everyone, I have just bought my first flat and it needs a bit of doing up and I'm just after a bit of advice.
I'm starting with the bedroom.
Walls and ceilings are stripped and I've found a plasterer who will skim it all to give it a good finish so I can paint directly onto the walls.
It's got carpet at the moment so I'm tearing that up to expose the floorboards.
Couple of questions:
1) Should I sand the floorboards first or would it be ok to plaster first, then sand?
2) Should I remove the skirting boards to then put them back on afterwards? Or can the plastering and floor sanding be done with the skirting on?
Thanks!
kjones1829
Re: First Home Improvement Project Plastering Walls and Sanding Floors in Flat
by kjones1829 » Tue Apr 28, 2020 9:39 pm
I would suggest sanding the floorboard first before plastering. On the other hand, remove the skirting also and put them back after sanding the floor.
It is currently Wed Jan 15, 2025 9:23 am
