Advice on Rawl Plug into Brick Through Plasterboard
monkey3
by monkey3 » Sat Apr 28, 2018 10:20 pm
First post couldnt find anything searching but maybe too specific.
Looking for a quick reminder about putting rawl plugs in brickwork through the plasterboard.
From bad memory....drill hole (got sds drills) through plasterboard and into brickwork.
Screw into plug a small way. Push and hammer plug into brickwork (guessing thermolite as new build). Remove screw, place object up to wall and tighten screw fully.
Right or wrong? Any help welcome
Thanks.
Sometimewoodworker
Re: Advice on Rawl Plug into Brick Through Plasterboard
by Sometimewoodworker » Thu May 03, 2018 7:50 am
monkey3 wrote:Hi
Thanks.
Basically correct, just make sure the plugs and screws are long enough to hold in the brick.
It is currently Wed Jan 08, 2025 12:21 pm
