Low Pressure Kitchen tap and Specialist Low Pressure Taps
pineapple645
by pineapple645 » Tue Jul 31, 2018 1:23 pm
I am having a kitchen refit so new sink and taps. Water supply is direct - no tank. The mains water pressure at 3 bar is fine. But the flow rate is only 3 litres per minute due to old pipework from the mains and shared water supply.
Does this mean I need special low pressure taps? All I need is a tap that will work. The special taps I've seen refer to water pressure and since my problem is one of flow rate, I don't know how the figures translate.
daviduong
Re: Low Pressure Kitchen tap and Specialist Low Pressure Taps
by daviduong » Thu Aug 09, 2018 10:05 am
Did you check the water inlet pressure? Only one of them is weak?
pineapple645
by pineapple645 » Wed Aug 15, 2018 9:43 am
daviduong wrote:Did you check the water inlet pressure? Only one of them is weak?
The water company checked the pressure from the mains in the road and the pressure is fine at 3 bar. The low water flow is due to the pipework supplying my property being the old steel type which clogs up over time. Plus I am on a shared water supply with my neighbour - which is quite common in this rural area.
The only way to fix this is to replace the entire run of pipe with modern pipe - which at the same time would also give me my own supply. As the householder I would have to stand the cost of the pipework across my land and reconnection at the house itself.
Anyhow tap problem sorted for now. Found some which operate down to .1bar/low flow.
It is currently Fri Dec 27, 2024 6:22 am
