Easy Clean Hinges and Easy Clean Slider gets Stuck on Screw
Julia1971
by Julia1971 » Mon Sep 17, 2018 3:19 pm
Hello, could anyone advise please? I have double glazed windows with the easy clean hinges. In order to open them for exterior cleaning there is a sliding plastic part which must be depressed and then should slide along inside a groove. However there is a round headed screw in the groove which seems to cause the sliding bit to get stuck.
I'm wondering if the wrong type of screw has been used - ie should it be a countersunk screw? Or am I just not using sufficient force? I'm worried about breaking the plastic slider.
Please could someone advise what is normal with these easy clean hinges? Are round headed screws correct here?
matthew23123
Re: Easy Clean Hinges and Easy Clean Slider gets Stuck on Screw
by matthew23123 » Wed Sep 19, 2018 11:25 am
Hi your best option is to remove the screw and fit a flat headed screw instead
your upvc hinges would then slide over the screw and allow cleaning
any advice please get in touch
It is currently Sun Dec 22, 2024 7:38 pm
