Need to Take Down Ceiling Under Minor leak if Fixed?
Drjohn
by Drjohn » Tue Oct 30, 2018 9:49 pm
Thanks in advance for any advice!
We have a minor leak from an upstairs shower cubicle- only a few spots on he ceiling below. It's almost certainly from a badly applied seal at the shower tray directly under the shower head.
If I sort out the seal, is this enough? Can I just rely on the timber/plaster under the shower tray drying in time or do I need to strip anything back to dry etc? Is the appearance the only consideration once the leak is fixed?
Cheers!
collectors
Re: Need to Take Down Ceiling Under Minor leak if Fixed?
by collectors » Wed Oct 31, 2018 10:11 am
Depends on what the ceiling is made of. If its plaster board, good chance you can just re-decorate when dry. If its somthing like lathe & plaster, water can loosen the plasters grip & can come down at any time.
It is currently Thu Dec 26, 2024 3:01 pm
