New Pitched Roof Fitted Over Doorway but Does it Look ok?
stevekay
by stevekay » Sun Dec 09, 2018 4:49 pm
Had a new pitched roof built above a doorway. Looking down at the new pitched roof, it looks a bit poorly jointed. Appreciate any advice over whether this looks pukka.
greengrass
Re: New Pitched Roof Fitted Over Doorway but Does it Look ok?
by greengrass » Mon Dec 10, 2018 9:27 am
To me NO there should be a capping on the straight joint of slates where angles meet. What cowboy did that ?
If left and right angles then the left photo shows top capping no complete.
Were they "door knockers" cowboys looking for work or local cowboy and did you see where they parked their horse
stevekay
by stevekay » Mon Dec 10, 2018 7:24 pm
greengrass wrote:To me NO there should be a capping on the straight joint of slates where angles meet. What cowboy did that ?
Established local roofing company !
Thanks for the advice, appreciated. I got told the slate was purely cosmetic, as it's got lead flashing underneath.
greengrass
by greengrass » Fri Feb 01, 2019 12:22 am
[quote="stevekay"][quote="greengrass"]To me NO there should be a capping on the straight joint of slates where angles meet. What cowboy did that ?
Were they "door knockers" cowboys looking for work or local cowboy and did you see where they parked their horse[/quote]
Thanks for the advice, appreciated. I got told the slate was purely cosmetic, as it's got lead flashing underneath.[/quote]
Wrong! flashing goes on top of angles and look at bottom photo bottom of angle a small pies of slate is to short they should have cut a slate to fit not shove a piece in if rain gets in soaks the timber it will rot. Why is the slate cosmetic? That's bull doo doo's. What's underneath then ? Might be established but trade there not and is your main roof slate? Some councils insist the same material is used to match main roof. You cannot effectively seal an angled roof with flashing under it. Again did you notice where their horse was parked. Take a look at some angled bays same shape, you should see capping over the angles.
Makie-
by Makie- » Tue Feb 05, 2019 11:27 pm
You can do it this way, it is called close-peen. Usually we would put a lead strip running under the hip and then individual soakers under each course of slate.
It is currently Tue Dec 03, 2024 12:31 am
