2400mm Chipboard to Fix Holes in Bathroom Floor
6 posts   •   Page 1 of 1
Ashers
by Ashers » Wed Jan 02, 2019 4:24 pm
Afternoon,
I've had my On-Suite taken out and this has left three holes in the chipboard flooring around the size of a A5 piece of paper.
I've measured the width of chipboard and it appears to be 2400mm and I'm struggling to find chipboard to match. B&Q and Homebase seem to only have 1800mm max.
I intend to screw a wooden batten under the hole and then screw a piece of chipboard into this gap.
Please can I have your recommendations on alternative flooring to use OR where I can get 2400mm chipboard from?
Any other thoughts welcome.
I intend
Browndoff
Re: 2400mm Chipboard to Fix Holes in Bathroom Floor
by Browndoff » Thu Jan 03, 2019 3:39 pm
Actually, whatever the original material in your bathroom floor, I would advise STRONGLY against using chipboard in any area where it might get wet. I'd use only marine [is made with water-proof adhesives] or good, old-fashioned, tongue&groove floorboards.
As for the patches you suggest in the holes themselves - well, they really won't make any difference. As the hole is to be covered [along with the rest of the floor] by the new sheet of flooring - it can't be seen and the area will NOT be made any stronger by the patch. Only material directly supported by the underfloor beams [the original floor and the new sheet laid on top of it] can bear any load from above [like YOUR weight].
The patch, as you describe it, would be supported ONLY by the screws in the wooden cross-bar.Would you like to bet on them taking your weight on their own?
collectors
by collectors » Thu Jan 03, 2019 5:01 pm
Ashers
by Ashers » Thu Jan 03, 2019 6:16 pm
collectors wrote:https://www.wickes.co.uk/Wickes-P5-T+G-Chipboard-Flooring---18mm-x-600mm-x-2400mm/p/164516?utm_source=google&scid=scplp164516&sc_intid=164516&gclid=CjwKCAiAgrfhBRA3EiwAnfF4tlVjubnRm-LlBMDRW-Y5eeN5GQIBSQJm-rgZo7WrItRbLj_Tj-HR5RoCsBYQAvD_BwE&gclsrc=aw.ds
That’s only 18mm
Ashers
by Ashers » Thu Jan 03, 2019 6:19 pm
Browndoff wrote:Actually, whatever the original material in your bathroom floor, I would advise STRONGLY against using chipboard in any area where it might get wet. I'd use only marine [is made with water-proof adhesives] or good, old-fashioned, tongue&groove floorboards.
So you’re saying not to patch and replace the whole chipboard area?
Still would need to find 2400mm thick chipboard.
The room is no longer an on-suite so won’t be in contact with water.
collectors
by collectors » Fri Jan 04, 2019 10:25 am
[quote="Ashers"][quote="collectors"]https://www.wickes.co.uk/Wickes-P5-T+G-Chipboard-Flooring---18mm-x-600mm-x-2400mm/p/164516?utm_source=google&scid=scplp164516&sc_intid=164516&gclid=CjwKCAiAgrfhBRA3EiwAnfF4tlVjubnRm-LlBMDRW-Y5eeN5GQIBSQJm-rgZo7WrItRbLj_Tj-HR5RoCsBYQAvD_BwE&gclsrc=aw.ds[/quote]
That’s only 18mm[/quote]
https://www.wickes.co.uk/Wickes-P5-T+G- ... m/p/164536
It is currently Sun Nov 24, 2024 11:13 pm
