removing paint from brickwork
6 posts   •   Page 1 of 1
bobalob1
by bobalob1 » Sun Sep 02, 2007 10:15 pm
Any ideas how i remove the paint from my exterior brickwork. i was told to use nitromorse but this didnt seem to work that well, not to mention the cost as i've got around 20 sq m to remove
Bob
prbaxter
by prbaxter » Mon Sep 03, 2007 8:36 am
Hello bob,
I found that the paint on our exterior brickwork started flaking off whilst I was pressure washing ivy suckers off the face of the wall.
So you could try a good pressure washer. Our paintwork is very old though, newer paints may be more resistant.
Good luck,
Prb
bobalob1
by bobalob1 » Fri Sep 07, 2007 12:20 am
hi prb
thanks for the reply but i have already tried that on a test area and it tended to blast the mortar out of the joints as much as clean the bricks so that is my last resort if there are no products
thanks again
Bob
pablo2
by pablo2 » Thu Sep 27, 2007 10:53 pm
There are specialised companys that use a combination of sand and water jetting , allternatively there is a product Peelaway . this product must be neutralised afterwards and i wouldn,t recomend it if you where going to paint it .
jwr
by jwr » Tue Oct 23, 2007 10:56 pm
Light sandblasting is an option , it can be very accurate if you use a small blaster , which will save removing mortar , It is however very messy , but it will remove ALL the paint in a very short amount of time and is probably the only option if you really want to bet all the paint of .
stew
by stew » Sat Nov 03, 2007 8:40 pm
yes sand blasting will be the answer with care you should miss the pointing and blast the bricks.
It is currently Fri Nov 22, 2024 5:27 pm
