Needing Help With Installing a Dishwasher and Connecting it up
maj_ly_mad
by maj_ly_mad » Sat Jan 12, 2019 2:12 pm
hi guys.
Im wanting to install a dishwasher in my kitchen. There is an attatchment under the sink connected to the cold water pipe. its a Brass Drain Cock and was wondering if i can connect a dishwasher to that to get the water supply. If so how can i do it. if now what work arounds can i do?
Many thanks
Mike
Browndoff
Re: Needing Help With Installing a Dishwasher and Connecting it up
by Browndoff » Sat Jan 12, 2019 9:37 pm
Leave the drain-cock alone - you may well need it sometime.
You'll need to add a T-junction on the cold-water-feed to match the input-hose to the dishwasher and a drain to remove the dirty water. This is usually an open U-pipe [35mm plastic-pipe attached to the sink-drain] into which you can stick the output-hose from the new machine.
Of course, you'll also need a power-supply socket with an ELCB [Earth-Leakage Circuit-Breaker] for safety.
For a 'hidden' unit, you'll need a door to match your other kitchen-cabinets - otherwise you'll just need a gap beneath your work-top to match the size of the dishwasher.
Good luck!
It is currently Mon Nov 25, 2024 3:42 am
