Different Layers After Stripping Wallpaper Banner off
Kat660
by Kat660 » Sat Jan 12, 2019 2:34 pm
I have stripped a wallpaper banner in my bedroom, which went round the middle of the walls all around the room. I have stripped it all but it has left different layers and patches here and there. Part of it would be left with 2 different paint layers or it would gone back to the plasterboard. How can I fix this without getting a plaster in or whatever. As it is in the middle of the walls. And not the whole wall. Can I use easi fill and skim on the area all around, prime it with a watered down emulsion or pva then sand and paint. Or is there something i can use like poly filla smoothover and paint once dried? Whats the best and easiest solution?
gc1967
Re: Different Layers After Stripping Wallpaper Banner off
by gc1967 » Mon Feb 18, 2019 11:17 pm
Scrape off all hard edges and then using a caulking board skim over it with easi fill, allow to dry and lightly rub down, and reskim if needed and rub down again, apply a thinned down coat of emulsion over the filler and allow to dry and then paint your walls.
It is currently Tue Nov 26, 2024 1:36 am
