Should I use Vapour Barrier Before Wooden Cladding?
GH14
by GH14 » Tue Jan 22, 2019 10:29 pm
Hi, I'm thinking of cladding the outside of my house, it's made of mass concrete and stone. Should i put a vapour barrier on before I put the 50x25mm battens?
B4Less
Location: 3rd Floor, 207 Regent Street, London, W1B 3HH
Re: Should I use Vapour Barrier Before Wooden Cladding?
by B4Less » Tue Apr 30, 2019 8:48 am
I would suggest using a vapour permeable layer. this will allow the movement of air between the cladding and the concrete inner leaf.
By doing so it will prevent the buildup of moisture between the 2 layers and reduce the risk of mold or mildew in behind the cladding where you cannot see it and prevent any rot that may occur.
Regards, Build4Less
It is currently Fri Dec 27, 2024 4:57 am
