Socket Burn't and Cracked but Fuse Didn't Trip?
7 posts   •   Page 1 of 1
brendanxx
by brendanxx » Mon Mar 25, 2019 10:34 am
Attached is pic of double socket in my washing machine shed. The socket no longer works and I don't know why what made it so cracked and burnt - also a bit confused as to why the fuse didn't trip. I suppose it could have been moisture getting in, but would that have resulted in such burning? I imagine it's not a hard job to simply change the socket but would welcome any thoughts as to why this might have happened. The plug worked perfectly well before.
thanks
Brendan
Re: Socket Burn't and Cracked but Fuse Didn't Trip?
by Mr White » Mon Mar 25, 2019 6:06 pm
It has overheated because of a bad connection, which fuses do not "detect" so that is why the fuse did not blow.
Change the socket AND the plug, use a well known brand of both to prevent it re-occurring.
by ericmark » Mon Mar 25, 2019 7:51 pm
Unusual to see that on neutral pin, as said poor connection causes it, you may find cable damaged.
But will need both socket and plug changing.
brendanxx
by brendanxx » Wed Mar 27, 2019 10:24 am
Sorry for delay in replying. Many thanks for swift advice. I will change the socket and also the plug - although when I plugged the washing machine into extension cable (thinking the problem was simply with the socket) it worked all right - I guess though that I should still change plug - better safe than sorry!
cheers
Brendan
collectors
by collectors » Wed Mar 27, 2019 4:09 pm
Ditto with the last 2 comments. You can often find older washing machines can put more strain on a socket & plug as they had larger heating elements & higher wattage motors that can push a 13amp plug/socket unless good quality.
brendanxx
by brendanxx » Sat Apr 13, 2019 1:35 pm
About to change socket but confused
(1) can't find socket like the old one - socket +light switch - only ones for cookers (maybe that's what I need?)
(2) Is there some way I can use a simple double socket - put a plug on for the light?
(3) If (2) what should I be looking for in a double socket? I'm attaching photos of two from B&Q. (the usb one is 13 amp.) - and my damaged one.
Any help greatly appreciated. Sorry about being such a complete beginner!
Brendan
by Mr White » Sat Apr 13, 2019 9:16 pm
Since the patress is for a single socket it would be easier if you buy a single socket.
Click here
Cheaper at screwfix Click here
You can even get a grey one Click here
I am not going to mention the red one.
It is currently Wed Sep 18, 2024 2:22 pm
