Coping Saw Blades to cut MDF Skirting Without Damage
beajou
by beajou » Thu Jun 13, 2019 4:18 pm
I'm needing to produce seven coped internal corners in fully finished MDF skirting. I've had a few practice attempts but have found that my coping saw blade seems too coarse and tends to skip and tear the MDF finish as I start (or finish) depending on which direction I begin to follow the profile of the board.
It seems to me as though I need a blade with more than the 14TPI that I'm currently using but after extensive searches and many phone calls I've drawn a blank and it seems as though 14TPI is all there is on the market. Having said that, I did find a saw with 15 and 16 TPI but I don't think that would improve the situation much. Does anyone know if moreTPI coping saw blades are available (and where to get them) or perhaps could suggest a less aggressive way of starting or finishing the delicate area at the top of the coped joint please?
beajou
Re: Coping Saw Blades to cut MDF Skirting Without Damage
by beajou » Mon Jun 24, 2019 9:30 am
Have found my own solution - start cut with junior hacksaw and then use this cut as a guide to introduce the coping saw blade to complete the coped joint.
It is currently Sun Nov 24, 2024 4:51 am
