Wallpapering onto Large Amount of Filler
BillsInLondon
by BillsInLondon » Thu Jun 27, 2019 9:42 am
Hi there,
There’s a large hole that I’ve discovered that has, at some stage, been filled with a foam filler. The wall paper has been stuck directly onto this but it obviously hasn’t taken long for it to peel off.
Any tips on how to stick the paper back on? Any special adhesive or painting on a primer first be of use?
Many thanks,
Bills
robshort18
Re: Wallpapering onto Large Amount of Filler
by robshort18 » Thu Jul 18, 2019 11:30 am
I would have away with some of the foam filler and skim the surface with plaster or poly filler. Sand with medium grit paper and then wallpaper over it... Just my 2 cents
It is currently Fri Nov 22, 2024 4:49 am
