by ericmark »
Wed Jul 03, 2019 6:55 pm
For any electrical item, it must be suitable for the environment, I don't know how much moisture is in your bathroom, or distant evolved, so it may be permitted to fit the heat link, although it may need to go in an enclosure, the same as the boiler, it may or may not be permitted in the bathroom.
One has to use some common sense, many boilers are sealed, they have no connection to room they are fitted in, and if you mount the heat link inside a water proof enclosure then it too has no connection to the room.
Next is not so easy, where the thermostat is placed is where it measures the temperature, so that needs to be where you want the thermostat to measure, there are exceptions, the EvoHome thermostat measures the temperature from the TRV heads, not the display point, and Nest works with Energenie MiHome, I am not sure how it interconnects? It may be that if using linked TRV's you can fit the thermostat where you like? since it has not been cold since the thermostat has been fitted, I am not sure.
But you don't talk about using TRV heads, so the thermostat needs to be in one of two places, either coolest room in the house, with no alternative form of heating, and no outside door, or the main room in the house, "nest screen in my bedroom" does not seem to fit either.
So it would seem there is an error.
