Additional light and 2 gang socket in Garage
Archno1
by Archno1 » Thu Sep 06, 2007 6:06 pm
I would like some advice please, on wiring up the above. I currently have a single swich serving a single rose in my double length garage. I am replacing this light with a strip light and connecting it to a 2 gang switch at the other end of the garage.
This light will then be operated by 2 switches. The other connection in the 2 gang switch will serve an additional strip light. This light will only be operated by this one switch.
I have purchased the required parts, including 4 core wire, which I believe is what I need. I have also bought 2 junction boxes.
Please could somebody explain the wiring set up to me in laymans terms. I am reasonably sure of what to do , but need some assurances!!
facwiz
by facwiz » Sat Sep 08, 2007 1:23 pm
You have the idea already, just run the 3core & E from your existing switch to the other, shouldn't need JB's, wire this cable the same at each end, and your existing cable to the L1 and L2.
It is currently Sat Nov 23, 2024 7:54 pm
