Chimney Removed and Roof Retiled but Only With White Fabric Underneath?
Tips, tricks and information on how to spot rogue and cowboy builders and also a platform for you to post and warn others of cowboy builders you may have encountered and help to spread the word of their dodgy dealings
pinmike
by pinmike » Sun Aug 11, 2019 11:34 pm
We've just had our chimney stack removed and the hole in the roof retiled but instead of the same thick black material which is under the existing tiles, they've used a much thinner white material, maybe breathable polyester, so just that and the tiles.. With all the wind this weekend, it flaps about if I'm in the loft, and come winter I expect it will be freezing. Is this normal practice for filling in after removing a chimney?
It is currently Thu Nov 21, 2024 10:11 pm
