Hi There,
We have a 1920's semi-detatched house with a large roof.
The ridge tiles/hip tiles need re-pointing.
We have a roofer that we're considering to help with the job.
He's recommending using Flexim Roof Putty for re-pointing the ridge tiles/hip tiles.
I've looked for reviews regarding this material but can't find many on-line.
He won't be re-bedding the ridge tiles/hip tiles; he just intends to re-point using Flexim (he may need to grind out some of the current mortar pointing where this has not already fallen out).
He feels the ridge tiles/hip tiles are heavy so won't fall off; he feels they seem to be well bedded in most places. He feels that pulling up/re-bedding the ridge/hip tiles may damage some of the highest (smaller) tiles under the ridge/hip tiles (making a bigger job than necessary).
Can Flexim Roof Putty be used just for re-pointing or do you need to fully re-bed the ridge/hip tile into this putty for this material to work effectively?
Will Flexim bond well to the older existing mortar, if/when ground out of the joint (do you need to apply some sort of primer/pva to help create a stronger bond)?
Any feedback would be welcome.
