Putting Down new Floorboards for LVT
carbar
by carbar » Mon Jan 13, 2020 10:25 am
Hello.
I am intending to put LVT in my bathroom. The existing floorboards are very uneven, so I am intending to remove all the floorboards and put down a new floor, probably a single sheet of chipboard.
If I do this, will I still need to put plyboard on top of the new floor before laying the LVT? If I do, should the plyboard be screwed down or just laid on top?
Thanks,
Carl
crazydaze
Re: Putting Down new Floorboards for LVT
by crazydaze » Wed Feb 26, 2020 4:05 pm
Yes, you will need to install 6mm Flooring Grade Ply, leave gaps between adjoining boards of 1-2mm, th Micro-Coat or Feather edge screed the joints and Glue the LVT to this finished surface.
It is currently Sat Nov 23, 2024 2:11 am
