WC Cistern not Filling with water
martin2007
by martin2007 » Wed Sep 12, 2007 12:57 pm
Could someone please let me know the reason why my WC Cistern does not fill back up with water when the flush buton is pressed? Could you let me know what i need to do to repair this?
kbrownie
by kbrownie » Fri Sep 14, 2007 2:48 pm
hi martin2007,
A little more detail maybe needed, does it sound like it's trying to fill or no water noise at all? sometimes the float jams or gets trapped depending what mechanism it is, it could be that! Just check inside to see if anythings stopping the float from rising.
KB
martin2007
by martin2007 » Fri Sep 28, 2007 10:40 pm
hi kbrownie
sorry about late reply. The cisten sounds as if it is trying to fill with water and the float does not appear to be jammed so i am not quite sure what the problem is?
It is currently Mon Dec 02, 2024 4:51 pm
