Electric hot Water Heater in Flat
nmac234
by nmac234 » Wed Feb 12, 2020 5:44 pm
3 electric rads, 2 hot taps and mixer shower and using immersion on an all-electric flat!
Any other type of heater can I use instead of immersion tank?
Kanro
Re: Electric hot Water Heater in Flat
by Kanro » Sat May 09, 2020 10:54 am
Do you need a tank? Because I have been using a tankless electric water heater and I am pretty happy with it.
AndrewFellson
by AndrewFellson » Thu Dec 16, 2021 11:46 am
I used a boiler for heating when I lived in a rental house for a while. It's quite convenient and I'm glad the owner installed it. I think you should consider buying a boiler, it would be just what you need.
by ericmark » Fri Aug 12, 2022 7:21 pm
It is more down to the electric supply, it will not be over 100 amp, but it could be a lot less.
For a supply from the DNO not likely to be less than 60 amp, but in a flat common to find a house has been converted to a number of flats, and the DNO supply is shared between a number of flats.
I lived in a caravan with a 16 amp supply, but to do that I needed to store hot water, with only a 1 kW water heater.
So to answer the question one have to consider maxium load, can't do that with information given.
It is currently Wed Dec 04, 2024 8:21 am
