Cold tap Turns on at Full Power
tez1982
by tez1982 » Thu Mar 26, 2020 7:38 am
Just moved into a new house. The cold tap in the kitchen has a strange behaviour.
When you turn it on slowly nothing happens, then there is a sudden clunk and the tap comes on at full power. You can then dial it back to a normal flow rate and clean up all the water.
Any ideas? Easy fix?
KevinJason
Re: Cold tap Turns on at Full Power
by KevinJason » Thu Mar 26, 2020 1:15 pm
It's a common problem,
I am not sure you are talking about sink tape or simple
If you are using with a sink faucet, check the supply valves underneath it move it counterclockwise until they will go to open them entirely.
It is currently Fri Nov 22, 2024 10:21 pm
