Fixing 25KG 55 inch TV to Wall
Hms151291
by Hms151291 » Mon Mar 30, 2020 4:06 pm
When I tap my wall it sounds slightly hollow (no cracking and no bubbles). I want to fix a 55 inch tv (approx 25kg) to the wall with a swivel mount so it can move away from the wall. What would the best way be to do this? Do you think I could just use a normal mount or should I do something different to support it better?
I know without seeing the actual wall it's difficult but just some general direction would be useful.
Thanks.
Re: Fixing 25KG 55 inch TV to Wall
by stoneyboy » Mon Mar 30, 2020 10:59 pm
Hi hms151291,
The issue is not the mounting but what wall fixings to use.
You need to determine whether you are fixing into a stud partition wall, or a masonry wall - possibly dry lined.
Without this information we cannot advise.
Regards S.
It is currently Fri Nov 29, 2024 12:37 am
