Advice on Covering top of Skirting and Expanding Foam
Aj7123
by Aj7123 » Thu Apr 02, 2020 5:18 pm
I am completely new to this so I do apologise if I have posted in the wrong area.
I noticed cracking on the top of a skirting board so I stripped it back and found that the previous owners had done a poor job.
The skirting on one end of the wall approx 2cm away from the wall compared to it being level on the other side
I have filled the gap with expanding foam but I am now stuck as to what I should do to cover the top
I have thought of beading or using filler/caulk.
I have tried to attach photos but the files are too big so any advice based on what I have described will be appreciated.
Thanks in advance
Alex
Re: Advice on Covering top of Skirting and Expanding Foam
by stoneyboy » Thu Apr 02, 2020 11:20 pm
Hi aj7123,
With a gap that big whatever you do will be a bodge.
Suggest you use decorators caulk but you will need 2 or 3 goes to beat shrinkage.
Regards S.
It is currently Thu Jan 02, 2025 3:49 pm
