Hanging Mirror on Crumbly Plaster Wall
Cwill
by Cwill » Sun Apr 05, 2020 6:04 pm
I am trying to hang a mirror having just decorated a room in our house. When we drilled into the wall a load of plaster crumbled away and we’ve previously had issues with rawl plugs just pulling plaster away. What should we hang it with?
Re: Hanging Mirror on Crumbly Plaster Wall
by stoneyboy » Sun Apr 05, 2020 11:22 pm
Hi cwill,
You will need to drill through the plaster and into the brick/blocks behind it. You can then use plastic plugs but use screws heavy enough not to bend in the plaster layer.
Regards S .
George441
by George441 » Mon Apr 06, 2020 8:24 am
Why need to drill a fresh wall?
Leave it...I mean no need to drill anymore.
You can yus this removable adhesive wall hangers. It is able to carry 5 Lbs. I got it from amazon. You may try this... If it doesn't work then try to drill.
It is currently Fri Nov 15, 2024 3:26 am
