Plumbing washing machine and Fridge freezer to same tap
Andyp1978
by Andyp1978 » Sat Apr 18, 2020 2:25 pm
Moving into new house. Bought new fridge with water supply. 1 cold water tap under the sink as normal. Can I, with the correct fittings, connect both the washing machine & the fridge water supply to this tap? Will there be any issue with drinking water sharing the same tap as the washing machine? I believe it would be fine but the Mrs is freaking out??
Cold water tap, can fridge water and washing machine both be connected to this with the correct fittings?
Re: Plumbing washing machine and Fridge freezer to same tap
by stoneyboy » Sun Apr 19, 2020 10:19 pm
Hi andyp1978,
No reason why you should not do as you suggest apart from the issue of isolating two appliances with one valve.
Probably easier to replace the valve with a T and have two separate isolating valves (one reused and one new).
It is currently Tue Dec 24, 2024 1:39 am
