Heavy projector on domestic suspended ceiling
Sandtree
by Sandtree » Mon Apr 20, 2020 12:17 pm
Hi all
We have a 2005 purpose built flat which has a suspended plasterboard ceiling on an aluminium track system and a circa 16" void before the structural ceiling above it (looks like galvanised corrugated steel).
I want to put a fairly heavy projector (circa 16kg inc mount) up on/by the ceiling and right by the side wall (dot & dab plaster on some structural blockwork).
How would be best to do this? The fall back option is to put a shelf on the side wall and simply stand the projector on it but this would be the ugliest implementation. I assume this is far too heavy to be supported by the suspended ceiling alone?
I was wondering if it wouldn't be possible to cut a hole in the ceiling, use brackets on the side wall in the void and then have a board connected to these flush with the ceiling to which to mount the projector?
If this idea works, how do I tell if a bracket is suitable for use above/in suspension rather than under/in compression the shelf? What thickness should the board be to support 16kg via 4 screws?
It is currently Thu Oct 31, 2024 8:22 pm
