Correct wiring new light fitting
Gilbo777
by Gilbo777 » Sun May 03, 2020 7:31 pm
Hi, I’ve read through various posts , please can you confirm I have this correct? Photos attached.
I’m replacing a plastic light fitting that goes into a rose with a metal one that just attaches to the ceiling with a bracket
I believe I should put the switched live into the Live terminal (blue with brown around it)
Earth into Earth terminal (green yellow)
Neutral into neutral terminal (black)
And as I haven’t got a spare terminal use a terminal block to connect live (red) and live (brown)
Can I cut the double terminal block in half to save space?
Is it ok to wrap the cable inside the fitting as I want it a lot shorter than supplied ?
Is it ok that there is just one earth that I can see, or might another be there when I remove the rose?
Sorry for all the questions, I want to get this right.
Thank you
Re: Correct wiring new light fitting
by Mr White » Sun May 03, 2020 10:51 pm
Yes you can cut the choc bloc in half.
There might be another earth wire.
Gilbo777
by Gilbo777 » Mon May 04, 2020 8:34 am
Thanks, but just to confirm have I got the wiring correct?
It is currently Sun Nov 24, 2024 6:01 am
