Self levelling latex screed in shed/office
wood1e
by wood1e » Sun May 03, 2020 8:12 pm
I am looking to use some self levelling latex/screed on my shed/office.
The concrete base is a little rough and as we concreted in two sections the first section, nearest the door is lower by about 3mm compared to the back section. Both sections are 3.83m X 2.66m.
What I am wondering is if I use latex screed to level and smooth everything out.
So that would be about 1mm to smooth out the back section, then working towards the door onto the front section, lay 4mm - (3mm to meet the original back level ) plus the additional 1 mm to meet the new level.
Or do I have to lay the 3mm first to level the front section to the back section. Then lay 1mm over the top (once first section dried) across the complete floor?
Many thanks in advance.
Re: Self levelling latex screed in shed/office
by stoneyboy » Mon May 04, 2020 10:55 pm
Hi wood1e
Depends on which self levelling compound you use. Some can fill 3mm in one hit. Read the instructions but don't forget to dampen the thinner areas.
wood1e
by wood1e » Mon May 04, 2020 11:24 pm
Thanks for that I will find one that can do 4mm in one hit. As it seems easier.
As the frame is wooden and isn't sealed against the concrete base, it does sit tightly, but there is always going to be some gaps, is it worth looking for a very thin plastic lining just to sit around the base? or maybe run some sealant along just to make sure?
by stoneyboy » Tue May 05, 2020 10:34 pm
Hi wood1e
Suggest you use general purpose silicone sealant to close the gaps.
wood1e
by wood1e » Tue May 05, 2020 10:55 pm
Many thanks for that.
It is currently Fri Jan 03, 2025 2:36 am
